Mobile Only
This library allows you to redirect desktop users to mobile by displaying a QR code alongside instructions for the user to follow.
Starting Development
Section titled “Starting Development”You can use this library by downloading a standalone zip containing the necessary files, by linking to our CDN, or by installing from NPM for use in a webpack project.
Standalone Download
Section titled “Standalone Download”Download the bundle from this link.
Unzip into your web project and reference from your HTML like this:
<script src="zappar-mobileonly.js"></script>Reference the zappar-mobileonly.js library from your HTML like this:
<script src="https://libs.zappar.com/zappar-mobile-only/0.0.2/zappar-mobileonly.js"></script>NPM Webpack Package
Section titled “NPM Webpack Package”Run the following NPM command inside your project directory:
$ npm install --save @zappar/mobile-onlyThen import the library into your JavaScript or TypeScript files:
import * as MobileOnly from "@zappar/mobile-only";Detecting Browsers
Section titled “Detecting Browsers”The MobileOnly.isMobile() function returns true if a mobile browser is being used:
import * as MobileOnly from "@zappar/mobile-only";const mobile = MobileOnly.isMobile(); // booleanconsole.log(mobile);User agent can be provided to the isMobile() function, if not specified, navigator.userAgent is used:
import * as MobileOnly from "@zappar/mobile-only";const mobile = MobileOnly.isMobile('Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/74.0.3729.169 Safari/537.36');console.log(mobile);Displaying the UI
Section titled “Displaying the UI”The QR code shown is generated from the current window.location.href.
You can show the redirection UI using MobileOnly.showUI(). This should be used alongside MobileOnly.isMobile():
if (!MobileOnly.isMobile()){ MobileOnly.showUI();}The showUI function appends the elements as children of document.body, with z-index of 10000.
Customization
Section titled “Customization”showUI() function may be customized using an options parameter. Here’s the available options alongside default values:
type Options = { header? : string, // 'Almost there...'; instructions? : string, // "Use your phone's camera to scan the QR code below"; footer? : string, // 'or visit'; url? : string // window?.location?.href || '0.0.0.0';}Example:
if (!MobileOnly.isMobile()){ MobileOnly.showUI({ url : 'www.zappar.com' });}This shows the following UI:
