Importing Examples
To get started quickly or to get some inspiration, we have a number of example projects that can be imported directly into Unity.
Importing Example Projects
Section titled “Importing Example Projects”To import these helpful sample template projects, go to the Package Manager. Change the dropdown menu to In Project and you’ll see an additional Zappar option.
You should select either one of the two samples available, depending upon whether or not you are using Unity SRP.
