Using External Packages
Once you have successfully installed a package into your project using the Dependencies Browser, you can start using it in your project.
Some packages might require additional configuration or setup within your project. Always refer to the package’s official documentation for specific instructions.
Using external packages in a script
Section titled “Using external packages in a script”Third party packages can be used in a custom script; for example, in a Custom Component or Custom Behavior Action.
- Open the script file where you want to use the package
- At the top of the script file, require the package by using an
importstatement* - You are then able to use the functions and utilities provided by the package in your code
*For instance, if you have installed a package named
example-package, you would write something like the following:import * as ExamplePackage from 'example-package';
Example script
Section titled “Example script”The below script is an example of using an external package in a Custom Behavior.
// Imports...import { gsap } from "gsap";
interface ConstructionProps { // Add any constructor props you'd like for your behavior here}
/** * @zbehavior * @zparents three/Object3D/Mesh/Box **/export class externalPackages extends Behavior<Box> {
constructor(contextManager: ContextManager, instance: Box, protected constructorProps: ConstructionProps) { super(contextManager, instance);
// Creating an easy to reference variable for // the component the behavior is attached to const box = this.instance;
// Register an event, in this case when a user // clicks or taps on the box this.register(box.onPointerDown, evt => {
// Use external package to animate the component gsap.to(box.element.position, {y : 2});
dispose() { // Clean up any resources // ... return super.dispose(); }}
// Uncomment below to run this behavior at design time// registerBehaviorRunAtDesignTime(externalPackages);
