Face Landmarks
In addition to tracking the center of the head (known as the Origin), you can use Face Landmarks to track content from various places on the user’s face. These landmarks will remain accurate, even as the user’s expression changes.
The available landmark positions available are:
| Landmark Position | Diagram ID |
| EYE-LEFT | A |
| EYE-RIGHT | B |
| EAR-LEFT | C |
| EAR-RIGHT | D |
| NOSE-BRIDGE | E |
| NOSE-TIP | F |
| NOSE-BASE | G |
| LIP-TOP | H |
| LIP-BOTTOM | I |
| MOUTH-CENTER | J |
| CHIN | K |
| EYEBROW-LEFT | L |
| EYEBROW-RIGHT | M |
Note that ‘left’ and ‘right’ here are from the user’s perspective.
To assign a component to a landmark position point, simply add the component to the FaceLandmarkGroup.
Adding a Face Landmark
Section titled “Adding a Face Landmark”By default, the Anchor Group exposes the following Face Landmarks:
- Left Eye
- Right Eye
- Mouth Center
- Chin
Adding a new Face Landmark
However, you may add additional Face Landmark components by using the following steps:
- Right click on the
Anchor Group - Go to
New, then find theARcategory. SelectFaceLandmarkGroupto add it to the Hierarchy - Click on the new
FaceLandmarkGroupin the Hierarchy and use theLandmark Positionproperty drop-down box to select the appropriate Face Landmark
Updating a Face Landmark type
Section titled “Updating a Face Landmark type”You can change the FaceLandmarkGroup type of this component at any time. To do so:
- Click on your chosen
FaceLandmarkGroupcomponent in the Hierarchy - Head to the Node Properties Panel. Find the
Landmark Positiondrop-down menu and then select a new attachment point
