Code Completion
Code Completion provides intelligent autocomplete suggestions for code within Mattercraft script editors. It analyzes file context to generate relevant completions for TypeScript, CSS, and GLSL code.
Code Completion activates automatically when:
- Typing in the script editor
- Cursor is positioned after incomplete code
- Context suggests a completion is beneficial
- Sufficient file context is available
To use:
- Begin typing code in any script editor
- Pause at completion points
- Review suggested completions (displayed as gray text)
- Accept with
Tabkey or continue typing to dismiss
Completion Types
Section titled “Completion Types”Single Line
Section titled “Single Line”Completes the current line based on context:
// Type: "const position = "Multi-line Blocks
Section titled “Multi-line Blocks”Generates complete functions or code blocks:
// Comment: "// create a click handler"API-Specific
Section titled “API-Specific”Provides Mattercraft API completions:
// Type: "this.zcomponent."Best Practices
Section titled “Best Practices”Comment-Driven Development
Section titled “Comment-Driven Development”Use comments to guide completions:
// Create a rotation animation that loops infinitelyDescriptive Variable Names
Section titled “Descriptive Variable Names”Use clear variable names for better context:
const rotationSpeed = // Better context for suggestionsconst x = // Less context availableType Annotations
Section titled “Type Annotations”Include types for more accurate completions:
const myComponent: MyCustomComponent = // Provides component-specific suggestionsExample Completions
Section titled “Example Completions”TypeScript Function
Section titled “TypeScript Function”Input: // create a function that rotates an object
Completion:
private rotateObject(object: Node, speed: number): void { const transform = object.getComponent(Transform); transform.rotation.y += speed * Time.deltaTime;}CSS Animation
Section titled “CSS Animation”Input: /* smooth button hover effect */
Completion:
.button:hover { transform: scale(1.05); transition: transform 0.2s ease-in-out; box-shadow: 0 4px 12px rgba(0, 0, 0, 0.2);}GLSL Shader
Section titled “GLSL Shader”Input: // vertex shader for wave effect
Completion:
attribute vec3 position;uniform float time;uniform float amplitude;
void main() { vec3 pos = position; pos.y += sin(pos.x * 10.0 + time) * amplitude; gl_Position = projectionMatrix * modelViewMatrix * vec4(pos, 1.0);}
