AR Web Embed
This feature is only available on our Business plans.
AR Web Embed is a trigger type that allows you to easily embed your ZapWorks Designer projects into a website.
When you create and publish a ZapWorks Designer project, you will have the option to create an AR Web Embed trigger. This trigger contains HTML embed code which you can simply copy and paste into a website as an iframe.
Here is an AR Web Embed of a plant plot configurator you can interact with to see how it works.
Below is an example of some AR Web Embeds live on a website, which you can explore further here.
To learn more about AR Web Embed and to get started using it, head over to its documentation page.
