Face Tracking
To place content on or around a user's face, create a new FaceTracker
component:
<ZapparCamera/>
<FaceTracker >
{/*PLACE CONTENT TO APPEAR ON THE FACE HERE*/}
</FaceTracker>
The group provides a coordinate system that has its origin at the center of the head, with positive X axis to the right, the positive Y axis towards the top and the positive Z axis coming forward out of the user's head.
Note that users typically expect to see a mirrored view of any user-facing camera feed. Please see the section on mirroring the camera view earlier in this document.
Events
The FaceTracker
component will emit the following events on the element it's attached to:
Event | Description |
onVisible |
emitted when the face appears in the camera view |
onNotVisible |
emitted when the face is no longer visible in the camera view |
Here's an example of using these events:
<ZapparCamera />
<FaceTracker
onNotVisible={(anchor) => console.log(`Not visible ${anchor.id}`)}
onVisible={(anchor) => console.log(`Visible ${anchor.id}`)}
</FaceTracker>
Face Landmarks
In addition to tracking the center of the head, you can use Landmark
to track content from various points on the user's face. These landmarks will remain accurate, even as the user's expression changes.
To track a landmark, construct a new Landmark
component, passing your camera, face tracker group, and the name of the landmark you'd like to track as props:
export default function App() {
return (
<ZapparCanvas>
<ZapparCamera />
<FaceTracker />
<FaceLandmark
target="nose-bridge"
{/*PLACE CONTENT TO APPEAR ON THE NOSE BRIDGE HERE*/}
</FaceLandmark>
<directionalLight position={[2.5, 8, 5]} intensity={1.5} />
</ZapparCanvas>
The following landmarks are available:
Face Landmark | Diagram ID |
origin | A |
eye-left | B |
eye-right | C |
ear-left | D |
ear-right | E |
nose-bridge | F |
nose-tip | G |
nose-base | H |
lip-top | I |
mouth-center | J |
lip-bottom | K |
chin | L |
eyebrow-left | M |
eyebrow-right | N |
Note that 'left' and 'right' here are from the user's perspective.
Face Mesh
In addition to tracking the center of the face using FaceTracker
, the Zappar library provides a number of meshes that will fit to the face/head and deform as the user's expression changes. These can be used to apply a texture to the user's skin, much like face paint, or to mask out the back of 3D models so the user's head is not occluded where it shouldn't be.
To use a face mesh, create a child mesh component, attaching FaceBufferGeometry
within your FaceTracker
component, like this:
import { FaceBufferGeometry, /* ... */ } from '@zappar/zappar-react-three-fiber'
return (
<ZapparCanvas>
<ZapparCamera />
<FaceTracker>
<mesh>
{/* FaceBufferGeometry requires tracker group to be passed into it */}
<FaceBufferGeometry />
</mesh>
</FaceTracker>
</ZapparCanvas>
At this time there are two meshes included with the library. The default mesh covers the user's face, from the chin at the bottom to the forehead, and from the sideburns on each side. There are optional parameters that determine if the mouth and eyes are filled or not:
<mesh>
<FaceBufferGeometry
fillEyeLeft
fillEyeRight
fillMouth
fillNeck
</mesh>
The full head simplified mesh covers the whole of the user's head, including some neck. It's ideal for drawing into the depth buffer in order to mask out the back of 3D models placed on the user's head (see Head Masking below). There are optional parameters that determine if the mouth, eyes and neck are filled or not:
<mesh>
<FaceBufferGeometry fullHead />
</mesh>
Head Masking
If you're placing a 3D model around the user's head, such as a helmet, it's important to make sure the camera view of the user's real face is not hidden by the back of the model. To achieve this, the library provides HeadMaskMesh
. It's an entity that fits the user's head and fills the depth buffer, ensuring that the camera image shows instead of any 3D elements behind it in the scene.
To use it, add the entity into your HeadMaskMesh
entity, before any other 3D content:
import { HeadMaskMesh, /* ... */ } from '@zappar/zappar-react-three-fiber'
<ZapparCamera />
<FaceTracker>
<HeadMaskMesh />
{/*OTHER 3D CONTENT GOES HERE*/}
</FaceTracker>
